주요 콘텐츠로 건너뛰기
수리, 조립, 자르기 등 특정 작업에 사용되는 공구에 대한 수리 정보입니다. 수리에 적합한 공구와 그렇지 않은 공구의 사용법을 알아보세요.
Pro Tech Driver wobbly bits
Quick question about the screwdriver and the bits: Are the bits supposed to be wobbly and loose when attached to the driver? They stay in the coupling just fine but have a lot of side to side play. Is this normal/by design? If so, why was the driver designed this way?
Thanks in advance~
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
There's a little play but not wobbly. Can you give a link to exactly which driver you got (they have changed over the years).
이 답변이 도움이 되었나요?
점수 3
댓글 9개:
Thanks for the response Mayer! I believe this is the new 2016 version, it came with the recent Fix the World special.
https://drive.google.com/file/d/1B2wB3LL...
[링크된 제품이 누락 또는 비활성화 됨: IF145-360]
I just tested mine and there is little play in it but I would consider it wobbly. Take a look in the driver hole and see if the might be something in there (like a tiny screw) that would prevent the bit from fully seating.
Looks clear, just the barrel and the magnet. Are you able to roll the bits around in yours, making a light clicking sound? I realize that "wobbly is a pretty subject term so my apologies XD
I can turn it just a hair. There is certainly not enough play to make it click. iFixit does give you a lifetime warranty on it if you feel it is defective, they will be happy to replace it.
댓글 4개 더보기
댓글 달기
답변을 추가하세요
Haoqian Wen 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 9
전체 시간: 376
