주요 콘텐츠로 건너뛰기
The OP-1 is a portable music workstation incorporating a synthesizer, sampler, sequencer, multitrack recorder, drum machine, mixer, and controller. It was released in 2011.
49 질문 전체 보기
Why is my OP-1 not turning on?
I have been storing my OP-1 and using it since 2013. The other week it stopped turning on; currently, when I flip the power switch, I hear the power get to the speaker but the screen does not glow at all. Is this a screen issue, ui issue, or is it something else? It has turned on previously but it only works after I perform a firmware update or sparingly at any other time.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 5
댓글 3개
Hello @amccaw1590 , Have you found a fix?
Mine stopped working yesterday night. I thought it was because the battery was empty but when I connected it to my laptop nothing happened.
I hear the power get to the speaker but same, the screen remains black.
I didn't upgrade the firmware. Just use it and then it stopped working :(
I tried to reset the factory settings but didn't work.
Any idea how to fix it?
Were you able to fix this?
Hey, has anyone been able to resolve this issue or find a place to diagnose and repair the problem?
댓글 달기
답변 2개
가장 유용한 답변
I’ve had this problem as well. I was able to fix using the instructions here:
https://www.reddit.com/r/OP1users/commen...
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
It has happened a couple times to me and has required a firmware update both times
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
How did you update the fw if it doesnt turn on?
댓글 달기
귀하의 답변을 추가하세요
Angelo McCaw 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 20
전체 시간: 2,556
