apple hi-fi won't work on mains, it only works on batteries.
Hi, my apple hi-fi won't work on mains supply, it only works on batteries. help
좋은 질문 입니까?
좋은 질문 입니까?
Hi @iain_sinclair ,
You will have to open the device and then check the connections from the mains power inlet to the motherboard.
Here is a link that hopefully may be of some help.
If you cannot see (or test, using a DMM- digital multimeter) what the problem is, take some close up pictures of the motherboard and perhaps someone will be able to help you further. Here's how to do that. 기존 질문에 이미지 추가하기
해당 답변은 도움이 되었습니까?
24 시간 전: 3
7일 전: 4
30일 전: 8
전체 시간: 211
댓글 7개
Please explain. Do you mean it won't work on wall power?
Reed Crosby 의
yes, thats correct it won't work on wall power
Iain Sinclair 의
Have you tried a different outlet?
Aiden 의
yes tried different wall outlets and different power lead, the problem is with the apple unit.
Iain Sinclair 의
did you drop it before? anything happen before it broke?
Aiden 의
댓글 2개 더보기
