주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Why is my lock button not working anymore?
Hi there,
I decided to renew the hardware of my iPhone 6 in order to extend its life and bought a new battery, lighting and jack connector, earpiece and loudspeaker from ifixit Europe.
Replacing components was pretty easy thank to the guides I found on the website and I did it all in one go.
The only exception was the removal of the old battery. I tried taking away the glue stripes as shown in the guide, but they broke and went under the battery, so I had to lever it out with some of the tools. I am afraid I may have damaged something because when I reassembled everything, the lock button didn't work anymore.
Now it may not depend on the way I removed the battery, maybe I just moved something without noticing(?).
Does anyone know what I can do to check what happened?
Any help is much appreciated.
Thanks
St3fan0
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
You may follow this step:
Power off
Remove the front screen assembly
Remove the battery
Unplug the dock connector assembly
Remove the logic board
Fix the stuck power button
Replace the logic board
Replace the battery
Reconnect the display assembly
est your newly fixed iPhone 5 power button
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
st3fan0 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 3,199
