주요 콘텐츠로 건너뛰기
Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
1233 질문 전체 보기
How to get my iPhone to DFU mode - please help me
Hello,
I hope you can help me, because i tried almost everything i could find in google, here what happened by order :
1 - I was getting searching, so i though it would be fixed if i update.
2 - I updated it from 10.3.2 to 10.3.3 .
3 - In the middle of the updating process, iTunes displayed an error.
4 - iPhone switched to recovery mode automatically.
5 - [pc] iTunes detected my phone and i tried to update it, failed.
6 - iTunes no more recognize it.
7 - Tried a macbook and it recognized it finally, but it failed to update, and no more recognize it again.
8 - I downloaded ReiBoot, my iPhone was recognized, i tried to remove recovery mode, it did.
9 - Now, when i turn on iPhone, it displays the logo for 5/7 seconds turns off, and keep doing this each time i press the power button.
Looking forward for your help !
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
Hold the home button while the iPhone is plugged into the computer, then turn on the iPhone but keep holding the home button.
It should go onto the recovery mode screen. Select restore from iTunes or 3Utools.
Looks like firmware is bricked and needs to be restored, not updated.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
To boot into Restore Mode: power off the device, hold the home and power as if you are doing a restart, but do not release the buttons until the iTunes logo displayed. Your device is now in Recovery Mode. Good luck!
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Thank you for the quick answer, i tried that before, doesn't work, here is a video of me doing what you suggested https://streamable.com/f0apz
댓글 달기
Coonect your device to the PC and then lanuch 3uTools, then see what mode is your device in.
If it is in DFU mode or recovery mode, try to use Easy Flash to restore your iPhone.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Bigfooooot 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 86
