주요 콘텐츠로 건너뛰기
2011년 상반기 모델, A1278 / 2.3 GHz i5 또는 2.7 GHz i7 프로세서.
782 질문 전체 보기
820-2879 LCD connector shorted now won't power up
Hi, I have an 820-2879 where the LCD connector locking arm shorted out the connector.
I have a green light on charger but no power up. I am trying to learn board repairs so thought a good one to start on.
PP3v42_G3H is at 3.48v but
I'm finding PPBus_G3h on the output of F7040 to be going from 12.8 - 2.8 pause then starts again at 12-8volts and goes down.
I am trying to learn so presume U7000 is what helps produces PPBus_g3h is that correct?
Q7030 has the same irregular voltage on pin 4.
Am I looking down the right line, can I have some help/advice please on where to go next?
Could it also maybe be something trying to turn on then can't hence why it goes back through the voltage cycle.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개:
@mccltd this is of course after you changed the connector? Best person to let you know would be either @reecee or @tcrs_circuit
Resistance between pins 17/18 and 27/28 of U7000?
댓글 달기
답변 1개
You could have shorted something out.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
dave 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 5
전체 시간: 86
