주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
battery percentage dropping, from 50 to 1
Hi all,
Quick question :
i have an iphone 6s.
battery is sometimes going from 60 or 50 procent to 1 procent.. the 1 procent can bee for several hours..
sometimes i don't have this problem .. strange..
I measured out the battery and that was good. I checked the life of the battery and still above the 90 procent , ( what i figured after the measurement)
what could it be? the IOS 10- 11 "bug" draining the battery or giving faults ?
TIGRIS or TRISTAR?? could that be a possibility ?
what would i do? : hard rest to reset the battery?
Thanks in advance
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
가장 유용한 답변
I think you are on the right track with thinking U2. Check the charging circuit to see if you are experiencing :Ghost charging" (Fake charging)
해당 답변은 도움이 되었습니까?
점수 3
댓글 3개:
Hi,
Now i did a hard reset ( + a software update to IOS 11.2.1 ) and fully charged the phone, i'm trying him out.. and he is working ( discharging) fine... so far..
but : if i check the amperage when charging i see the amperage going from 0.33 tot 1.2 ( continously between those amperages.. ) ...
I will try to drain the battery now and charge him again..
battery was empty, the discharging was normal. when i plugged the phone in to charge : it started to charge but the amperage range was between 0.33 and 1.06 amp. after a minute of 3 the amperage was continiously on 0.93 amp.. the fluctuating amperage is not normal i think... and it's not all the time...
any suggestions ?
댓글 달기
Here's a good thing to check. Make sure to check and see if your iPhone 6s is affected by the battery recall, because that symptom matches completely to the recall. I've attached a link where you can punch in your SN and see. Also, if not affected I recommend downloading coconutBattery and seeing what it says about the number of loadcycles and life remaining. Let me know what happens!
6s Recall Check
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Hi Ryan
The phone is not in the range of te "broken" phone's...
I checked the loadcycles ( 256) an life is on 90 procent...
strange ...
댓글 달기
Have iPhone 6S doing the exact same thing, however I have had the battery changed by Apple a while ago with the recall… I went to apple and they thought it was a software issue (want me to wipe phone & see if it still happens) … funny it’s only started happening after recently updating iOS, currently on 12.3.1… note: it can be showing 1%, reboot it’s back to showing correctly (30% to 50%)… dodgy iOS on on this version phone
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
It's a bad battery. There's nothing else to it as I do battery replacements on these phones daily on latest iOS version.
If the replacement battery was working for a while then it happened again it's a bad battery.
댓글 달기
귀하의 답변을 추가하세요
Kevin D 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 8
전체 시간: 16,181
