주요 콘텐츠로 건너뛰기
Fourth generation Samsung Android tablets. Released in April 2014.
359 질문 전체 보기
I charge the tab but it wont charge that much in the time it took
Hi!
I had this problem a week ago.So I came home after my exam to see it had only been charged 36 when I started it it went to 20.I restarted it and went to 90.I used it and worked for the day. then I tried to charge but it wouldn't work I drains she battery full and put it back to charge it charged. Then I took it 36 again. Then when I plugged it in showed 26 .I started but it went 2 percent .I put it in for 4 hours and then I came to check it was at 15 % now if I charge it will barely charge plz help as I really need it
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
I also forgot to tell that I use and s7 charger as my own broke and it charged fine for 7 months
댓글 달기
답변 1개
가장 유용한 답변
Is the charger getting warm ? If not, maby it is not charging or der battery is very old and should be replaced !
I had the charge estimates jump around on my Tab4 7" also recently when it was cold outside, the capacity suddenly dropped from 50% to 30%. But that was only once.
I think it is the battery slowly dying. Mine is about 4 years old.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
No the charger is not warm but the tab charges so slow like it does 5% in an hour
I have only had the tab sine up end of 2014/15
댓글 달기
귀하의 답변을 추가하세요
Idk 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 5
전체 시간: 81
