주요 콘텐츠로 건너뛰기
The Ford Super Duty (also called the F-Series Super Duty) is a series of trucks produced by Ford Motor Company, an American automaker.
31 질문 전체 보기
seats and interior! 03 f-250
I would like to do a whole interior swap but more important than that are my seats! I need to know what vehicles seats threw what years will fit my 2003 F-250 lx 7.3 Super Duty. I would also like to go all power if I could. If anyone can help, i'd appreciate it. Thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
As far as seats go can i use Expedition or Excursion or any other vehicile with slight modifications?
댓글 달기
답변 2개
선택된 답변
You can use the seats from a 1999 to 2007 f250 or f350 as far as making them power all the hardware is in the seats so no problem and if this was an option on your truck the wiring will already be there . But if your truck is a base model dont count on it as for the wiring . I would check under the seats for the wiring harness . f its not there then you'll need to glean the one from the truck your getting the seats from . you may also need to grab the fuse panel while your at it if the proper fuses arent listed in the panel you have . Hope this helps
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
1999 - 2007 Ford Super Duty OEM Truck Seats:
https://www.oemcarandtruckseats.com/coll...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
uue Edde 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 55
전체 시간: 7,251
