주요 콘텐츠로 건너뛰기
Repair guides and support for small electric personal space heaters.
Duraflame infrared heater wire and 3 prong cord getting hot?
I have a Duraflame infrared quartz heater 5200 BTU 1500W 12.5 Amps.
When The heater is in use,I have noticed that the wire right at the prong connection is getting really hot.I have done electrical work and know this is very bad.It is a 16 GAWG cord,should replace it with a 14 GAWG cord?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 4개
선택된 해법
I'd consider a 12 gauge, but 14 at the minimum and do a web search on the unit for recalls and or harm caused by this machine. Here's a table on the maximum Amps per load carrying capacities on AWG gauge wire: http://www.powerstream.com/Wire_Size.htm
You can get replacement cords here: http://www.omega.com/heaters/hsc.html
이 답변이 도움이 되었나요?
점수 3
댓글 4개:
+ 12.5 amps go with a 12 gauge. Those heater cords do get hot
Don't forget the wiring in the wall! And the condition of the outlet its self. Are they able to support the load? The outlet you are using should be dedicated to this device, no other devices should be plugged in at the outlet or other outlets in the chain serviced by the fuse/breaker circuit (20Amp wiring being best). Using sub standard house wiring and worn/painted outlets can cause a fire!
I can't get mine to cut on and off! What do I do
@glennamullins Use a multimeter and start with the switch. Find where you are getting continuity and where it stops.
댓글 달기
My Duraflame heater power cord was getting hot at the location where the wire enters the power plug. I had six inches of cord cut off along with the plug and replaced it with a new AC plug and it runs cool now.
I think my Duraflame heater is great.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
All winter we've used our duraflame heater without any issues. I woke up around 1 am to the smell of hot burnt wiring. Found that the fireplace said Er meaning something was wrong. Shut the fireplace off the Er was still flashing ended up pulling the plug from the outlet and sure enough it was in the beginning stage of fire. Hot to touch with the smell of burned wires.
The outlet is correctly wired to handle only the one heater. It also is on its own breaker.
What would cause it to malfunction?
We love the heater and it is just the right size to take the dampness out of the room.
The heater was purchased in 2014.
댓글 달기
i have a duaflame heater with a motor noise how to fix this?
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Ive had one totally apart, ended up trashing it. Good luck finding any helpful info. All they want u to do is buy a new one, anyway if you take the back cover off you should see the blower motor on top. With it unplugged spray a little silicone lub or wd on the bearings on each side. Hope i helped u a little
thats my email with yahoo if u need help
댓글 달기
Lease help me I love my heater ;but i can't get it to cut on and off? What do I do?
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Please help me how can I get my DuraFlame heater to cut on and off
댓글 달기
답변을 추가하세요
Rick Riley 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 6
지난 7일: 31
지난 30일: 125
전체 시간: 18,654
