google account previously synced on this device
i have done a hard reset on my tablet but it tells me there was a google account previously synced on this device and i don't know what the account name was
좋은 질문 입니까?
좋은 질문 입니까?
Go to settings and add user
When it asks for Google email type a bunch of letters hold to copy press assist type se press settings select user add
해당 답변은 도움이 되었습니까?
What if there is no add user
Thank you wrightbethany18!!! Finally a solution!!
Excuse me how did you get a solution to pass the Google part
When I do that assist does not pop up
My tablet also has no assit button
After doing a factory reset, it wants you to sign in as the original owner. This is a workaround. Go to settings and add user. Here's how:
When it asks for Google email:
Type a bunch of letters, press and hold to copy> choose assist> type or say settings> (in the settings menu) select add user> add YOUR Google email info.
When you choose assist, you will get a Google search bar. Type settings in that search bar and choose "enter" or "go". It will take you to the tablet's settings page. On that page, look for users, add user, manage users or something similar. (It varies by tablet brand)
It will take a few minutes to set up your new profile.
The original owner's profile is still there, but the tablet is completely usable. I haven't figured out how to remove it yet.
I hope this works for you too!!
해당 답변은 도움이 되었습니까?
I tried it but Choose to Assist does not come up. Now what?
It wont let me click on assist. Now what?
I have the same problem it won’t let me select assist
google patched this awhile back
at setup screen hold power and volume up that should take you straight to home screen
Assist button doesnt work need help getting to settings?
https://www.youtube.com/watch?v=-sf_DDnS...
Link above works for Voyager 3 only. I have used it with success 3 times. It is in Spanish but easy to follow. If link does not work it is on YouTube under Ray Tech RCA VOLLAGER 3 FRP GOOGLE BYPASS (Voyager is misspelled) Read the reviews this works but only on Voyager 3’s I spent Hours looking. Hope this helps NOTE…IF YOU HAVE ANDROID 7 AND ABOVE YOU CANNOT ACCESS ASSIST AND THERE ARE NO FIXES FOR RCA TABLETS AS OF THIS POST. I HAVE PUT THIS ALLOVER THE PLACE AND PEOPLE ARE STILL CONFUSED BY THIS FACT. AND JAKE IS A FAKE LOOK AT HIS PROFILE !!!!!!!!!
해당 답변은 도움이 되었습니까?
you have to unsync gmail in settings and reboot outside of factory reset
해당 답변은 도움이 되었습니까?
How do u reboot outside of factory reboot?
Fpund on forum xda,
“Thread but figured id add a note in case anyone comes looking later :
go through setup, enter wifi and when it comes up asking for previous owners info, hit back till you get to wifi screen, click on 'add wifi' then hit a few random characters, click and hold on the characters and then select 'ASSIST'.
When new window opens up, type chrome and select the chrome app when it shows in the dropdown menu, download and install google account manager 6.0.1 apk, then download and install quick shortcut maker, open quick shortcut maker and then type 'google account manager' in search bar. click on this and then from the options that open, select the 1 that ends with 'loginactivity' and then select 'Try IT', from the new screen that opens up, click the 3 dots at top right of screen and select 'Browser Sign-in'. Log in with your Google credentials, once it goes back to the quick shortcut maker screen, use power button to restart tablet, proceed through setup as per normal and instead of going to the google login screen, itll come up stating that your new accounts are ready for use.
once you have went through setup fully, goto settings and factory reset the tablet, this will get the tablet to a 'brand new out of the box' state and remove those previous credentials from your legally purchased 2nd hand tablet”
Thanks paulpjur!
해당 답변은 도움이 되었습니까?
This only works if you have BELOW Android Ver. 7. Assist is gone on anything above 7. Look at all the posts of people that do not have assist when they try this. I have been working on this for almost a year with the hope someone will find a solution. There are many Fixes for Phones but they will not work on RCA Tablets. I devote an hour every week trying to find a solution.
Hi Tenna, Hope I did come across as critical. I would love to sue Google over this whole FRP debacle. I wake in the middle of the night thinking I've got a solution w/no avail. Right now I have 3 different expensive RCA FRP locked Tab's of customers that are driving me crazy. I have a whole bunch of Techie friends helping me to try and find a solution. I have gone so far as to replace motherboards in FRP locked devices to make them work. I would like to inlist your help for the cause, if you have the time.
i have an rca Viking pro 10 i followed this video to unlock my tablet https://www.youtube.com/watch?v=HiqiEITv...
해당 답변은 도움이 되었습니까?
Yes it works, because you can access "ASSIST" as I have stated allover this post, if you can't access "ASSIST" you are out of luck. The person making it also mentions the reason it works is because the tablet is old and not updated to Ver. 7
Yes, I went through all the darn steps but I tried to use Assit and it won’t work, so my laptop is useless. It’s not fair that Google have this installed that renders a tablet totally unusable, even after the drive has been wiped clean. Dosn’’t make sense. It sucks big time.
해당 답변은 도움이 되었습니까?
Robert, You say "tried to use assist and it won't work." Do you have Assist? Does it show up as an option? If so, it should work.
Your going to have to find that account or find out how to write new software to your tablet go to Google and learn how to write software to your tablet was you know how find out the firmwAre for your device then go to Odin mode write the new software
해당 답변은 도움이 되었습니까?
if you have a usb port then after hard data reset, re boot using boot usb stick go into google sync and disable it,
then re- boot with flash drive or pay rca 125 bucks to do it
해당 답변은 도움이 되었습니까?
I have tried that many times and it did not work. Which Tablet did you have success with? I have unlocked many below Android 7.1 but anything above no luck.
For RCA TABLETS. I tried everything. Software downloads, resets etc. THIS WORKED. CHANGE OWNER, COMPLETE RESET. Yes, a lot of steps, but it worked first time I tried it.
해당 답변은 도움이 되었습니까?
Hello, FYI This ONLY Works for Android 6.0 and below!!!!!!!!!!!
well you actuality you don’t have to you a google acount you have already used
해당 답변은 도움이 되었습니까?
Hello, I know that many of the comments are from 2019 so I’m not sure how many of you still need help with this problem. I found a video on YouTube that helped me get past the “verify your account” screen. Make sure to watch the video until the end, because it will seem like the person who recorded the tutorial messed up. But it turns out they just needed to restart the tablet after doing all the steps. Hope this helps: https://m.youtube.com/watch?v=bhdkaSwpQ3...
해당 답변은 도움이 되었습니까?
This only works if you have "ASSIST" not on anything above Android 6
Hey Kathleen. 1ST OFF thank you for your seemingly neverending work on here. 2nd You have got to be tired of saying the same thing a million times because nobody reads thread completely. 3rd Im sure my tablet is 7 or above OBVIOUSLY because (no asst…..blah blah blah). However I was hoping (a massive hope) that since my tablet is a smarttab & not an RCA that maybe you might have some useful info for me? Or does it not matter (Smarttab/RCA) either way? Thank you in advance for your swift wisdom & response & keep up the good work!!!
해당 답변은 도움이 되었습니까?
Hi Brian, Can you please send me the specs. for your Smart Tab. It would be easier if you use my email...barnmom007@hotmail.com
Hey Brian, There might be a fix or workaround for you. Reply to my email above if you want to try it.
Hi Kathleen,
You have the patience of a saint!
I purchased an ONN Surf Tablet at an auction and am stuck. Just wondering if there is anything new or if you have any suggestions to get around the FRP. My email is mblegg93@gmail.com
Michelle
How to get passed the last synced device
해당 답변은 도움이 되었습니까?
Hello, Can you please clarify your question. I follow this thread closely and try to help where I can to explain what the FRP lock actually is.
How to bypass Factory Reset Protection (FRP) – reset Galileo Pro tablet when you don’t know original account/pass
On startup:
해당 답변은 도움이 되었습니까?
Hello,
I follow this thread closely. Look at all my Posts. This fix only works if you have ASSIST option. If your Tablet Android version is above 7 it will not work because ASSIST is not an option.
I’ve found that this tutorial allows me to break out of the initial interview. On voyager pro with android 7 I can get into Chrome, youtube, maps. But I was not able to find the final step that would get me into settings… So still stuck with a brick of a table
해당 답변은 도움이 되었습니까?
Hello Dave, Because I follow this thread closely just got this post from you. I have tried similar but not this exact one. When I've time later, I'll give it a shot. Just don't get your hopes up because I've found what works for Andriod phones does not usually work for Tablets! As you found out you can only use it for a basic Launcher because the final step is not available. I am a Pro at this and if I can't get working we are all still out of luck.
Kathleen, I now have fully recovered access to the tablet using the method I posted.
I was hesitant installing the 3rd party apks, but in the end following the instructions step by step was the key.
The only deviations were:
1) if you connect to wifi , you can install APK from internet and do not need the USB
2) I used a throw away account to recover the tablet and after I was able to properly boot I then used "wipe" from the settings to reset the tablet again. This was just a precaution to not put my main account when 3rd party APKs were running.
The author shows 2 methods in one video. The first method didnt achieve much for me - go for the second one, that requires APK install.
Hello Dave, I have tried 3 day's. It will not work for Atlas10 Pro-S.
In Change Google App Settings I have no Location option.
I then tried instructions on the Techno Care APK Download page. I was missing options on those instructions also.
Your's orig. shipped w/Android 6 and updated, the one I have shipped w/7 to 7.2 which is why I'm missing options. It's the same as not being able to access assist.
There is a fine line w/the Android versions and what options you can access.
I have to commend you for finding this solution with hope that it will help others following this thread.
These old Tablets are not the greatest but I love to tinker and if I can get them unlocked they get donated to my local shelters. It's also a great learning experience.
On many occasions I have bought logic boards (motherboards) cheap on eBay and replaced them, that is the ultimate fix.
One last thing, these FRP locked Tablets can be used (convoluted) with any Launcher
Regards, Kathleen
I want to recover the Google account ovat isek oden tdonnic@gmail.com account and password code
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 79,380
댓글 120개
My daughter suddenly passed away taking all gmail accounts and passwords with her. I was going to give her new RCA Gilileo tablet to my 11 yr old granddaughter but even after the factory reset, it wants my daughter's google account. Is there no way to bypass this so my granddaughter can have her Mommys tablet?
Rhonda 의
Yes i have hard reset a tablet but could’nt open the previous synced google account please help me
Ahmad Konneh 의
How can I bypass this Google setting I have lost all access to my rca
Angela Marie 의
I did it!! I figured it out 10 straight hours using process of elimination!!! Omg I'm exhausted. Anyway I'll make a video or a full description on how to do it when I wake up :) super easy to takes maybe 10 minutes and nothing required but the tablet lol! reply here or email ill walk you through it I'm sure the video will take a few days to make.
Jake Deore 의
Sent you an email Jake.
Jason Halipchuk 의
댓글 115개 더보기
