주요 콘텐츠로 건너뛰기
2.2, 2.4, 2.5, 또는 2.6 GHz Core 2 Duo 프로세서
759 질문 전체 보기
swap logic board a1226 and a1260
Hello everyone,
I own a logic board a1226 and got a macbook pro model a1260 with a broken logic board.
is it possible to put a a1226 into a model a1260 macbook pro?
is there a problem that the a1226 is a 2,4 ghz and the a1260 is a 2,5 ghz?
There is a related post, but unfortunately it is the other way round:
Is the logic board in both model the same?
Aditionally, can it brake everything, when i put in another logic board?
Thanks in advance,
Lukas Danzer
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
가장 유용한 답변
Walter Galan, one of the best guide creators, appears to think they are interchangeable: MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Logic Board Replacement
The user that did do the change mentions slight alterations to the mounting screws and that he would change the bottom case if doing it again. For reference this is a Santa Rosa board in a Penryn machine. You may end up replacing the keyboard also because thet are different. Here's a direct comparison of the two machines. http://www.everymac.com/systems/apple/ma...
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
I haven't had a chance to really test out mine but so far yes it is possible. At least a a1226 board in a a1260 machine. With 2 changes. First the heatsinks are different. So you have to have the right heatsink. Some of the mounting points are different. No way around this. Then one of the standoffs inside the case is slightly off. They are just glued on though. So I popped it off and moved it over. I'd assume going the other way (a1260 board in a1226) wouldn't be any different. But try at your own risk. Btw I upped my process to a 2.6 in doing this swap. I was mainly wanting working FireWire ports but got this as a bonus. ;)
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Hi !
I´ve done this like 10x and successful.
My Question is if the GFX Chips suffers from different Voltage from the I/O Board...
Does the I/O Board have to be changed aswell ?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
dewy3 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 4
전체 시간: 4,819
