need a picture of under dash fuse box, 2000 ford mustang
need picture due to fact I do not know which fuse is for what. my fuse cover is missing
좋은 질문 입니까?
좋은 질문 입니까?
1 20 Cigar lighter
2 20 Engine controls
3 — Not used
4 10 Right-hand low beam headlamp
5 15 Instrument cluster, Traction control switch
6 20 Starter motor relay
7 15 GEM, Interior lamps
8 20 Engine controls
9 30 Mach 460 subwoofers
10 10 Left-hand low beam headlamp
11 15 Back-up lamps
12 2 Heated PCV
13 15 Electronic flasher
14 — Not used
15 15 Power lumbar
16 — Not used
17 15 Speed control servo, Shift lock actuator
18 15 Electronic flasher
19 15 Power mirror switch, GEM, Anti-theft relay, Power door locks, Door ajar switches
20 15 Convertible top switch
21 5 Instrument cluster and engine control memory
22 — Not used
23 15 A/C clutch, Defogger switch
24 30 Climate control blower motor
25 25 Luggage compartment lid release
26 30 Wiper/Washer motor, Wiper relays
27 20 Radio
28 15 GEM, Overdrive cancel switch
29 15 Anti-lock Brake System (ABS) module
30 15 Daytime Running Lamps (DRL) module
31 10 Data link connector
32 15 Radio, GEM
33 15 Stop lamp switch, Speed control deactivation switch
34 20 Instrument Cluster, CCRM, Data link connector, Securilock transceiver module
35 15 Shift lock actuator, Powertrain Control Module (PCM), Speed control servo, ABS module
36 15 Air bag control module
37 5 Adjustable illumination
38 20 High beams
39 5 GEM
40 — Not used
41 15 Brake lamp
42 — Not used
43 20 CB Power windows
44 — Not used
해당 답변은 도움이 되었습니까?
What number of fuse for dashboard
해당 답변은 도움이 되었습니까?
Erika Herrera #21 if your vehicle is a 2000 Ford Mustang
24 시간 전: 8
7일 전: 41
30일 전: 163
전체 시간: 49,576
