주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
iPhone 5s Stuck in recovery mode has black screen
I started having problems with my Iphone when 3g stopped working, wifi was good. Reset it still did not work. Couple hours later i was watching a video off youtube and it just crashed. Tried turning it on no response, plugged it into itunes which says it is in recovery mode and gives an option to restore but that will wipe everything and i have pictures that i have not backed up to icloud yet.
Got a Program called Reiboot that claims it could get around wiping the phone, detects the phone correctly dowloaded the correct firmware goes to "repair it" the apple logo appears then fades a couple of times then i get an error from the software to try again (this is the only time i get the screen to display anything, even when it's connected to itunes)
I have tried holding down the power and home button with itunes to get it out, it just disconnects and reconnect and itunes declares that it is still in recovery mode. Is there anyway i can recovery my photos and such before i try restoring it? i have tried 3rd party software but they cannot detect the phone and i can't use the default import option on windows as i can't select "trust this device" on my phone as the screen is black.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
there might be a hardware problem with the device. restoring might be the only thing you can do but i would try unplugging the battery for a few hours and plug it back in to see if it will come back to life. i am not sure what else to say as i have not seen this before.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Try downloading Redsnow. Go to extras and Recovery mode loop fix. It saves phones for me all the time. (Obviously when the phone is plugged in.)Hope it helps! If not I do have some other solutions.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
hey!! what other solutions do you have?
댓글 달기
its hardware problem hard disk error
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Lightsfaster 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 2,287
