주요 콘텐츠로 건너뛰기
모델명 A1707. 2017년 6월 출시, 이 MacBook Pro는 Kaby Lake 프로세서 최대 2.8 GHz 쿼드코어 Intel Core i7 프로세서와 Turbo Boost 최대 3.8 GHz를 사용합니다.
What does the top case consist of?
Just curious as I've been heard because of issues with ports, the whole top case needs replacing.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 6개
가장 유용한 답변
Excuse me.
Do you know if the top case consists of the speakers? Apple will replace my top case and I wonder if the speakers are going to be replaced.
ps: MacBook Pro 15" Touch Bar 2017
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
If you are having the uppercase replaced as far as the extended warranty program for bad keyboard then yes the speakers, battery and trackpad are all replaced within a refurbished uppercase.
To be clear you are not getting a new part just refurbished one. They replace the keyboard and battery as well as test the rest of the part before reusing it.
Thank you! Really appreciate it!
댓글 달기
The case parts are made from aircraft grade aluminum.
Can you explain more fully what your issue is. How about posting some images so we can see the damage. The USB-C ports are mounted to the uppercase independently.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Yes. The top case includes a new pair of speakers. I don’t know if this always happens, but my MBP 15” with TouchBar 2017 top case was recently replaced by a new one in a local Apple authorized service provider and it included: new battery, new keyboard, new speakers.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
did it include a new touchbar?
@Arch Mauricio Bermudez - Yes, it is part of the uppercase assembly.
댓글 달기
Ports are on the logic board, which is mounted in the top case.
Top case is mainly battery, keyboard and some other small components.
It should be under warranty if your model is this new
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hi,
My MacBook is now under repair before the end of the 4 years period.
do they replace the top case with same butterfly keyboard or something different?
Thanks
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Very late but I'm wondering this as well. I've been told to replace the top case from Apple but my issue is crashing does that tally up?
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
@tr0llboy - That doesn’t make sense!
What is the crash reports telling you?
댓글 달기
답변을 추가하세요
John Hamp 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 39
전체 시간: 48,646
