주요 콘텐츠로 건너뛰기
Samsung Galaxy Note 4는 2014년 10월에 출시된 셀룰러 스마트폰입니다. Galaxy Note 4 모델 번호는 SM-N910, SM-N910A, SM-N910T, SM-N910V 또는 미국 버전은 SM-N910R4입니다.
256 질문 전체 보기
weird transparent glitches on my note 4 screen, how I can fix it?
I have sprint galaxy note 4 (sm-n910p) that works successfully, but with one problem. The problem in the screen that splits to normal part in the top and transparent glitch part in the bottom. I don't know the reason of this glitch and I need your help please to remove it..
I try the following solutions but they don't solve problem:
1- I added new original stock firmware... and the problem still same..
2- I did a hard reset... and no change..
Please anyone help me?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
I'd test it with another LCD, if the issue disappears then you know what caused it.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Many thanks for you. Your answer is highly appreciated.
댓글 달기
Its a long time ago..
I get sometimes the same. Today 3 transparent screens over each other. It went away after 5 mn.
I made a screenshot of it but it is not to be seen at all!
If you look good the 'sheets' are a bit trembling.
Got the feeling to be hacked...!
No clue what to do.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
huss biohuss 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 5
전체 시간: 183
