주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.4GHz, 2.7GHz, 또는 2.8GHz 쿼드-코어 Intel Core i7 프로세서 (Turbo Boost 최대 3.8GHz).
274 질문 전체 보기
MacBook suddenly shut down and will not turn back on.
My MacBook suddenly shut down with about 17% battery left. We tried the shift, control, option, power key buttons and held them down simultaneously for 10 seconds. Then plugged in the power cord and hit the power key. The laptop turned back on. We entered our password to log in and it was loading at the bottom. Then it suddenly shut down again. Now we cannot get it to turn back on at all.
Suggestions??
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Just to confirm, you cannot turn on your MacBook even with the power cable plugged in?
Correct. The power cord is plugged in and it is lit up green saying 100% charged.
댓글 달기
답변 2개
가장 유용한 답변
Clean the cooling system, replace the thermal paste, and if you see anything that looks like corrosion or liquid then scrub the board with a toothbrush and 92% alcohol. and if you still have problems you may have to replace the magsafe power adapter and the keyboard with power button. This will be assuming liquid damage is present. Sometimes people are un aware that they have liquid damage. It can happen if a friend spills something on it, liquid is present on the counter, or moisture is somehow present. This will also help with a cooling system issue although in rare times the thermal heatsink has to be replaced.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Hi i had a problem with my macbook pro 2 days ago when i was using my mac suddenly shut down and not turning on, i had try to charge my mac but charging light doesnt showing i used 2 charger they are same that means not charging my macbook. I coundnt see any light around my mac’ now my mac is completely dead.
Do you have any solution please ?
댓글 달기
I would give brucewark's suggestion a try here:
How to bypass the power button on a 2012 MacBook Pro
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Ali Court 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 6
전체 시간: 7,777
