Trackpad and Keyboard Only Work at Login and After Loggin In
Hello! I have a 2013 MacBook Air 13” A1466 whose keyboard and trackpad only work once you get to login screen. Because of this, I am unable to boot into recovery mode, boot options, or hardware test with the internal keyboard. If I attach a bluetooth keyboard I am able to boot into these options. The board suffered a little bit of liquid damage and was transplanted into a new machine. Apart from not being able to use the startup boot options it seems fully functional.
I booted into AHT with external keyboard and it says there may be issue with trackpad and keyboard but they do work fine once you get to the login screen! I’ve tried SMC and PRAM reset to no avail.
Any help would be appreciated!
좋은 질문 입니까?
Which is your system? All of the A1466 models we really need to know what you have to answer.
Also where did you get the keyboard/trackpad you may have the wrong one. Can you give us the source and the P/N of what you bought.
Dan 의
It seems as though you didn’t read my post closely.
Jon Lewin 의
No, I did! Which is why I wanted to make sure. Your other post lists a 2014 so I wanted you to make sure what you have
So we have two different systems here.
Dan 의
Two different posts for two different systems for two separate issues, yes.
Jon Lewin 의
I got same issue and not found any solution yet. Thats crazy.
Claus 의
댓글 2개 더보기
