주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2016년 9월 16일 출시. Model A1661, A1784, 또는 A1785. 32, 128 또는 256 GB 환경 설정 / 로즈 골드, 금색, 은색, 검정색, 칠흑색 및 (Product)빨간색으로 제공됩니다.
No SIM card problem
I bought an iPhone 7 Plus with cracked screen when I put my SIM card at fist it works but 1 minute after the phone says no card sim I tried multiple times but the same problem appears
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 1개
I have No Sim problem too..how to fix this?
댓글 달기
답변 3개
선택된 해법
Plausible cause.
-Carrier Locked
-Damaged Sim Reader, really difficult especially with Phones.
-Carrier Settings need to be updated.
*Leave sim in unit, connect to wifi, go to Settings > General> About. This should trigger a carrier update, or simply updating the phone.
-Check Settings > General > Scroll down to Profiles
*Should be in the same area as VPN, and see if a profile from the previous user is interrupting the service (This is primarily dependent on your region/carrier service).
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I work at an electronics repair store, most of the time the solution is either a new sim card, or reset network settings (you'll have to reenter wifi passwords, but your phone will probably work, worth it).
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Juan's first suggestion is very likely, a straight talk or other prepaid carrier locked phone will appear as though it is receiving a signal and it will then fade away. look up the model number on a site like everymac.com for its specs. you will want the model listed under the Settings > General> About area, the model description on the back of the phone is generic
i have one iPhone 7 no sim card problem phone looking mother board issue plz help me any friends
댓글 달기
How can i undo the carrier problem wen ever i put in the line it says invalid sim, ie tht the carrier is not meant for tht sim, what can I do about this
I have an iphone 7
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Khalid el makhfi 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 24
전체 시간: 13,113
