주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
iPhone 5s bootloop with damage after DIY repair
Hello kind people of iFixit.
I have recently tried to replace the battery on my iPhone 5s, but I sliced trough the ribbon cable for the power button while prying the battery out. While I waited for those new parts to arrive I tested the iPhone, because one of the screw standoffs on the motherboard had gone missing and I was afraid I broke it. No long screw type damage, luckily. The phone booted and worked absolutely fine. Then I replaced the power ribbon and put the phone back together; bootloop. Something I notice when it reboots is that there is a small horzontal line over the screen for a split second.
I’ve tried reseating all cables, the board and all other components and trying it without the new ribbon but same thing. I have also tried restoring the iPhone. It goes into DFU mode fine, but after initiating the restore and shortly after the progress bar appears on screen it reboots with iTunes error 9. After closer inspection I noticed that a very small component next to the battery connector had gone missing. Could this be the reason why? https://imgur.com/a/a9pDX
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
yes boot loop- not recognizing battery and error because of missing component- a microsoldering job can repair this for you.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Bram Koert 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 58
