주요 콘텐츠로 건너뛰기
Repair and support information for HP Laptops, designed for home and home office use.
1039 질문 전체 보기
Change HD to SSD and upgrade RAM
Hello,
I have HP x360 13-s102TU touchscreen laptop. Currently it has 1TB hdd and 4 GB RAM. I wanted to check whether it is feasible to change the HDD to SSD and upgrade the RAM to 8 GB.
I was checking over internet, but havent found any substantial support in this regards.
Else, the only option remaining is to open the laptop and check.
Hoping for a solution on this.
Regards,
Rohan
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
댓글 달기
답변 1개
선택된 답변
Max RAM 8 GB 1x1 PC3 12800
Looks like you are good to go for under $200
해당 답변은 도움이 되었습니까?
점수 3
댓글 4개:
Thank you @j0vian for the quick help. Can you tell me whether there will be a remarkable improvement in the system performance after this change in terms of using lightroom and photoshop?
There should indeed be a remarkable improvement.
Considering OP has a 5400 rpm HDD an SSD should be an extreme improvement.
@rohankonge If satisfied with the answer please choose the answer as the chosen solution so the problem will be marked solved. Thanks
댓글 달기
귀하의 답변을 추가하세요
Rohandeep Konge 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 5
전체 시간: 699
