주요 콘텐츠로 건너뛰기
2012년 6월 출시 / Core i7 프로세서 Turbo Boost 포함 / 최대 1 GB DDR5 비디오 RAM
596 질문 전체 보기
How many cycles does this computer's replacement battery have?
I installed a replacement battery from iFixit for my MacBook Pro back in April 2017. As of today the battery has sustained 457 cycles. Apple says their batteries will last for 1000 cycles until they need to be replaced. I would like to know how many cycles the aftermarket replacement battery should be able to go through. I ask this because this battery has expanded to a point where it prevents most of the laptop's trackpad from clicking. This did not happen with the original Apple battery, and I wonder if it may be due to poor design of the aftermarket battery.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 4개
선택된 답변
All of our batteries have a one year warranty. @microfix6 can get in touch with us and we will happily replace it.
Regarding the quality of the battery, I've seen a number of factory-original batteries expand into the trackpad. There's even been reports of batteries expanding in brand new iPhone 8 models.
Aftermarket batteries can be lower quality than OEM parts, but they are not inherently worse. You just got unlucky. Either way, give us a call or shoot us an email. We'll take care of you :)
해당 답변은 도움이 되었습니까?
점수 4
댓글 1개:
Thanks for the info! I didn't know there was a warranty, so that's good news. I'll contact support.
댓글 달기
가장 유용한 답변
Hi,
I am not sure what iFixit's source is, but cycles are usually between 600-1000.
You shouldn't worry about that though.
Since you only bought that in April, it is still under warranty, and iFixit will happily exchange it for you.
Simply file a warrant claim here:
http://help.ifixit.com/contact
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
Swollen batteries are defective. However they're are a consumable and with 457 cycles it's about at a half life. This is kind of a judgement call and we may need to hear from iFixit on the warranty status @evan
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Do you tend to let the system run on battery a lot? Letting it to drain before recharging? If no then I suspect your logic board has a problem as 450+ cycles in 9 months is on the high side.
In any case get a fresh battery so your keyboard & trackpad aren't damaged.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Nick Marascio 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 9
전체 시간: 1,444
