주요 콘텐츠로 건너뛰기
Inexpensive 5 1/4" 4G LTE 2016 phone. Fixed battery, 2 SIMs, up to 64GB microSD.
40 질문 전체 보기
Why can't I change the screen orientation from portrait to landscape
When I turn my phone sideways it doesn't change its orientation at all. Only time it does is when I click full screen on a YouTube video. While I'm watching the video, I cant turn it back to portrait unless I leave the app.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
I recently came across the same problem. Same thing with YouTube, only time it goes to landscape. There is no “auto screen rotate” option in display, accessibility, or where I thought it was, in the drop down settings with like flashlight and wifi. I never changed any settings, that im aware of.
댓글 달기
답변 2개
선택된 답변
Hi ,
Have you checked that the screen rotation setting is enabled?
Go to Settings > Display > Rotation and enable auto -rotate screen
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Hi @Scott Pauley,
What is the make and model number of your phone if not a Blu Life One X (2016).
If it is a Blu phone, try starting the phone in safe mode to see if you can get screen rotation. (method should be the same for all Blu phones and a lot of other makes).
If you can, then a downloaded app is the cause of the problem. The trick is to find out which one. You need to uninstall each downloaded app, one by one, and test the phone in normal mode, between each uninstall until it works. The last uninstalled downloaded app will be the culprit.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Juwan “ClueGamer15” I 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 30
30일 전: 143
전체 시간: 6,677
