주요 콘텐츠로 건너뛰기
This iteration of Amazon's Kindle Paperwhite series was released on June 30, 2015. The Kindle Paperwhite 3rd Generation is a 6-inch, 300 PPI reading display tablet that is Wi-Fi capable. The designated model number is DP75SDI.
48 질문 전체 보기
doesn't open, hard restart, recharge and recognized on computer
Hello,
I have a paperwhite. Everything was normal until yesterday. I had recharged it on saturday. I used it on saturday and sunday (there should be still pretty much battery). But i couldn't open it on sunday evening. Couldn't restart/hard reset it. I plugged it on my computer. It didn't show up on my computer. Even if battery is dead, i thought i could see it on my computer as a USB stick. I charged it for 10 hours but still battery lamp is orange not green. What is the problem ?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 달기
답변 3개
가장 유용한 답변
I had the same thing happen to me twice already and both times the same thing solved it for me
I took my kindle out of the charger I took its case off and just left it bare.
I then left it face down on my nightstand and waited for a little less than 24 hours (i suggest waiting the full 24 hour time though just in case) and finally the kindle completed its restart sequence
I think this worked cause that the problem occurred right after you restarted so the kindle just needed to get some time to restart (i’m not sure if taking off the case and taking it out of the charger was necessary but u should still try it b/c thats how it worked for me)
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I found another page where everyone was saying hold down the power button for at least 30 seconds and it will reset the paperwhite. Resetting doesn't work for everyone. It didn't work for me. My paperwhite has said critical battery recharge now for 3 weeks. (yeah it is still on) Nothing happens and I held the button down for over a minute. Amazon sent me a replacement. It has an orange light while charging. The light turns green. I try to use it. I read for 20 minutes then I have to do something. The kindle goes to sleep. Then less than 30 seconds later I get a battery with an exclamation point on the screen. I have had the kindle for 4 days, read a total of 1 hour and charged it a total of 36 hours. Some replacement. Now I am waiting on Paperwhite the third to show up. I am getting worried there is a problem with the batteries and they are going to start catching on fire like the Kindle Fires did.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Try another charger if you haven’t already
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Turan Tanrıverdi 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 5
30일 전: 15
전체 시간: 5,295
