주요 콘텐츠로 건너뛰기
Repair guides and support for top and front loading Whirlpool brand washers.
425 질문 전체 보기
12 y/o whirlpool duet washer vibrating/shaking
My 12 y/o whirlpool duet suddenly started shaking & vibrating terrible. It's level and sits on cement. The drum isn't loose. Could a shock absorber or spring go bad so quickly to cause violent shaking? Also there's a small amount of water in the drum but it's not clogged and hoses are free & clear. Any help would be appreciated. Ty
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
It sounds like one of those 12yr old springs has sprung loose or broken. Front load washers have concrete around the drum to keep from jumping around and leveling it out.
The springs do take a good bit of a beating.
You should be able to see what the issue is by removing the front or back access panel and watch as a small load goes through.
Some machine can tell there is nothing in it, so it will not do a cycle.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Kelly Lee 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 8
전체 시간: 236
