주요 콘텐츠로 건너뛰기
2017년 11월 4일 출시. A1865, A1901. GSM 또는 CDMA / 64 또는 256 GB / 은색 또는 스페이스 그레이. ("iPhone 10"으로 발음합니다.)
1200 질문 전체 보기
iPhone X keeps restarting IOS 11.2.2 jUST UPDATED
Every 3 minutes the iPhone X keeps restarting after updating it to IOS 11.2.2. There is no way i didn't try from the previous solutions appeared in after the 2nd of December issues.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
My iPhone X is still restarting after all fixes I’ve found
댓글 달기
답변 6개
선택된 답변
Apple store replaced the phone with new one ! As it was a hardware production issue !
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
I am assuming you have tried
a) Settings --> General --> Reset --> Reset all Settings
b) backup the phone fully in iTunes
• put the phone in DFU mode
• restore iOS 11.2.2 again
• do not restore from the iTunes backup afterward yet
• set up as a new phone
• then restore from the iTunes backup you just made
• do a Settings --> General --> Reset --> reset all settings again
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I actually tried it but it was not helpful!
댓글 달기
First you have to clear that there is any issue in modem firmware.Check the meid of the phone by dial *#06#.If imei shows there may the hardware issue or wait for new update coz downgrade to old version is not possible on new generation iPhone.
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
Modem firmware shows 1.03.06, I tried *#06# and it just gave me the IMEI number nothing else so what is the issue. the update was just made so I don't think they will update again soon.
Have you tried restoring the phone yet? Make an iTunes backup for the phone before doing so you keep your settings, photos, contacts, messages and etc.
I tried restoring but it doesn’t work
댓글 달기
I’m having this issue too. Try turning your WiFi off. For some reason when I’m connected to WiFi my phone restarts every 3-5 minutes but when it’s on LTE it works fine. I’m going to Verizon today to try to get a replacement phone
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I'm having a similar issue, but it's spread out to every hour or so. My screen will go completely black. For a minute or two, any music I'm listening through headphones, or anything I'm watching on Airplay, will still be playing. But I'm unable to do anything during this time as my screen remains black. Once what ever I'm listening too, or watching, stops playing, my screen will remain black for another minute. It will then reset and prompt me to enter my password and everything is almost back to normal. Wherever I was in my media when the screen goes black, my phone will start playing from that moment as if what I was listening too while it was black, did not happen. If that makes sense.
iPhone 7.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I have the exact same issue which you described.
iPhone X on 11.1.2 (haven't updated since I got the phone in Dec)
댓글 달기
Update from my last post, turns out WiFi wasn’t the problem, it eventually went away but as soon as I’d restart my phone manually, the problem would come back and this past time it didn’t go away. I ended up going to the Apple store and got a replacement phone for free and I no longer ha e that issue so if you haven’t gotten it fixed yet I highly recommend you do that.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Ramzi 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 7
전체 시간: 18,677
