주요 콘텐츠로 건너뛰기
Unibody가 아닌 Core Duo & Core 2 Duo 프로세서
375 질문 전체 보기
SSD drive rebooting, reinstall OS X
Hello,
I m a bit new here,
My question: I having problems install reinstalling OS-X
It worked fine till I restarted my laptop. The now I'm getting the question mark yea!
When I open utilities and want to reinstall Mavericks OS-X. Than it's asking to select the drive for install, but there is no longer a drive to see. When I open Disk Utilities, there is the BASE System OS-X, but I don't see the SSD drive.
So if I try to reinstall OS-X using a flash USB, it stops have way, giving a stop sign.
How do i solve this? Suppose I have to reformat the drive, how do it manage this?
The SSD should work fine, it did , but now it's no longer in the list.
Any answer for this problem is welcome! Thanks
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 3개
Do you have access ta a Windows PC?
Please tell us your exact machine.
macbook pro 17 inch
댓글 달기
답변 1개
가장 유용한 답변
If you cannot see the drive then you cannot format the drive. You should run diagnostics by holding down d during startup. Most likely you have a failed ssd and it will most likely need to be replaced.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Jan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 7
전체 시간: 168
