주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
Unresponsive screen with stripes... After replacing battery
I gave my first try to using the iFixit 5S Battery replacement kit today. When it came back on, the screen worked but was unresponsive to touch and had white vertical stripes. I took the phone apart again and reseated everything and powered it on to see the same striped screen that was unresponsive to touch.
I'm assuming that I wrecked something while trying to install the battery (I did follow the full version of the instructions on the website).
Just wondering if there is some thing else I can check to attempt to recover the phone?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
You probably bent the screen cables over 45°C causing the ribbon flexes to be damaged from being folded.
If you have already tried reseating the screen connectors then you will need to get the screen replaced.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
귀하의 답변을 추가하세요
Harvey Wallingford 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 168
