주요 콘텐츠로 건너뛰기
Repair guides and support for top and front loading Whirlpool brand washers.
425 질문 전체 보기
Spontaneous lid lock light solid not flashing
After my washing machine has completed the cycle and the only light left on is the green light after the load has sat for a while suddenly the red lid lock light will come on. The light is not flashing it is solid. I will go to lift the lid and it will be locked I’ll put it back down lift it again and it comes unlocked and the light goes out. This is a sudden issue and it does not do it for every load. What could be the issue and remedy? Thank you
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off. If that does not do it, try putting the machine into diagnostic mode. The washer must be empty and the control must be in the OFFstate before pressing the touch-pad sequence to start the test.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
I would like to add to this question. After a brief period, the lid locks when the washer is empty. I have to unplug it for a minute before it will unlock. Any idea why? I don’t know how to put it in “diagnostic mode.”
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Hether 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 30
전체 시간: 4,020
