주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The Kia Sportage is a compact crossover SUV (sport utility vehicle) manufactured by Kia Motors, a South Korean automaker, since 1993. Between 1993 and 2005, the Kia Sportage was classified as a compact SUV.
Why would my dash and taillight fuse keep blowing 02 kia sportage
Is the fuse for the dash lights and tail lights keeps blowing but it only blows out while I drive
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
It is possible you have a short in your system. A short is where positive connects to ground. Best to check your tail lights and make sure that there are no frayed wires at or leading to them. Also check that there is no rust/corrosion or damage.
댓글 달기
답변 1개
That short could be hard to find. Here's what I'd do, after checking everything obvious. Find an old headlight bulb ( I always save stuff like that) and hook the high beam (which seldom burns out, the low beams go first) in place of the fuse. Be very careful with the wiring and tape the connections. Drive around and see if the light ever comes on brightly when you hit a bump or something. It may dimly glow when you use the taillights.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Glenn Sparks 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 9
지난 30일: 42
전체 시간: 1,313
