주요 콘텐츠로 건너뛰기
Repair and disassembly guides for Epson printer. The company was founded in 1942 as Daiwa Kogyo, Ltd., but merged with another company in 1959 to create Suwa Seikosha Co., Ltd.
My printer is saying paper jam with a loud noise
My printer is saying paper jam with aloud noise, why can I fix it?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
Im having the same issue. Did you find out how to repair?
I am having Epson L550, it's saying paper jam error, but there is no paper jammed..
댓글 달기
답변 3개
선택된 해법
It will either have a latched door at the back or the bottom of the unit, to remove any stuck paper that may have jammed up the mechanism. Try looking for and opening that door and cleaning out whatever may be in there.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Thank you this worked for us!
Thanks! The printer was instructing me to clear the paper from the paper cartridge/bottom of the printer... after seeing your suggestion, I opened the back of the printer and found two additional sheets stuck in the printer!
댓글 달기
I have a Epson ET-15000 and mine is doing the same thing and making a weird grinding noise but no paper in it anywhere. I’ve reset it several times and nothing changed?
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Just purchased the same printer and same thing, it was making a loud noise showing no paper but there was paper. Then now it was printing but the noise got louder
댓글 달기
I am having the same issue. Have you called Epson Support?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
June 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 13
전체 시간: 10,355
