주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Why is my phone not making calls, and why can they not hear otherwise?
I recently replaced the battery and the charging port/AUX port/microphone and afterwards everything worked perfectly except now if I try to make a call it will not ring and will just give me the error that the call failed. I believe that I am receiving calls just fine, but if I get a call or if I somehow manage to make a call then the person on the other side cannot hear me very well at all. I seem to be cutting in and out or just not getting sound to them all together. Any ideas of what this could be, what to check or what I should do?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
This type of repair is not my forte, but is it possible a flex cable or something of that sort was torn in the repair? That seems like a logical source of annoyance after a repair. If you know that's not the issue, I would suggest (from a more solid background of experience than my above suggestion) that you try restarting it with the power/home button restart a few times - I know someone with an iPhone 6 that, for seemingly no good reason, has gone completely nuts on multiple fronts, including being wonky with the actual phone part.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I did a factory reset and the problem seems to have gone away for now, if it comes back then I'll look at the internals again. Thank you!
댓글 달기
귀하의 답변을 추가하세요
Nathan Arnold 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 75
