주요 콘텐츠로 건너뛰기
1.83, 2 또는 2.16 GHz Core Duo 프로세서
281 질문 전체 보기
Clamshell sensor intermittently shows Open even when Closed.
I use my MacBook Pro in clam shell mode with an external monitor. Lately it's started to think the clamshell is open and activates the internal display even when the clamshell is still closed. If I press the case together on the right side it seems to work better.
Is the problem likely with the latch not holding the case together tightly enough, or more likely a problem with the clamshell open sensor? Is either one adjustable?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
a reed switch is used to determine if the lid is open or closed. a magnet is used to close the circuit of the switch, when the magnet is close to the reed switch.
in your MBP, the magnet is located in the display bezel, along the right side, about the middle. you can find its location by putting a paper clip near the right bezel until it sticks.
the reed switch is in the main body of the MBP, in a position on the right side that would match the magnet when closed. it's possible that either the reed switch or magnet have shifted slightly? or your lid isn't closing completely. I say this because when you press the lid, it seems the reed switch is closing like normal.
take a close look at the lid when closed to make sure there's not an abnormal gap. or if you have recently opened your MBP for servicing internal parts, make sure you didn't move the reed switch or magnet
I suppose it's also possible the reed switch is damaged, although that is less likely as it's a very simple device. I've heard stories of people running a magnet up and down along the right edge of the computer and the reed switch starting to work reliably again after that.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
joehuber 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 1,750
