주요 콘텐츠로 건너뛰기
{A1706 / EMC 3071}—2017년 6월 출시, 이 MacBook Pro 13”는 Kaby Lake 프로세서 최대 3.5 GHz Core i7 및 Turbo Boost 최대 4.0 GHz 포함.
276 질문 전체 보기
Replacement top body MacBookpro 2017
Hi, I got a lot of scratches on the aluminum top (where the Apple logo is). I tried to fix it with toothpaste, but it only made things worse. There is now a lot of small scratches on the logo and on the matte aluminum there are som brighter circles which looks really bad.
Also I cracked the plastic part under the screen where it says “MacBook Pro” think I should replace that ona as well...
Is it possible to buy replacement parts without having to buy the entire screen?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Not really, no. It's hard enough to change out just the LCD panel on those, that the aluminum housing would be cake in comparison. The problem is just getting to it and transferring the LCD panel over. With the retina displays the entire top housing is engineered together to where replacing the entire lid is really the only low to mid tech level feasible option. There are also companies that will likely refurbish that top lid, but it will cost upwards of $300 and require a downtime for the computer.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
What LCD panel?
댓글 달기
귀하의 답변을 추가하세요
Eivind Van 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 2,557
