주요 콘텐츠로 건너뛰기
This is the first generation of the Ford Escape, a compact crossover SUV. Production started in 2000 for the 2001 model year.
104 질문 전체 보기
Front and Rear Windshield Washers Not Working
The windshield washer fluid will not come out in neither the front or the rear. I checked the fuses and they are both fine. Any thoughts on what it could be? I watched a video on replacing the pumps and they mention there is a pump for each window so I'm not sure how likely it is for both pumps to go out at the same time. Thank you
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개:
Same problem here. Were you able to find a solution?
댓글 달기
답변 1개
I had to change both. There on the left side by the front wheel. I went to Ford to replace them.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Lucia Munoz 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 12
전체 시간: 1,724
