주요 콘텐츠로 건너뛰기
The BLU Vivo XL was released in January 2016 as part of BLU's budget line of smartphones.
Unable to hear during outgoing calls
After the latest update to my BLU XL2 I am now unable to hear during outgoing calls as well as any sound with the speaker during the calls or with Google assistant. My speakers work fine when watching video. Everything is fine when I receive a call.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 8
댓글 7개
You are correct @Grandy. It is the Google app. When I allow microphone permissions within the app the problem persists, but as soon as I disabled permission for the app. It went away. Thanks for your help!
Gabe........How did you disable permission for the microphone? Thanks in advance. Joe
I have this too! I can't hear a call when calling out, but when someone obviously answers, I press the record button & I can hear. Ugh. Thank you for the feedback, I took the ok Google advice as well as the carrier service. I'll see what happens!
Thank you for this...I've had this same problem after the last update. Disabled the ok Google... problem solved.
I hve buy vivo y 81 one month ago, but there a hearing problem, I am not able to hear incoming as well as out going calls . Tp hear calls , I have to on loud speaker. This the problem in this phone.
댓글 2개 더보기
댓글 달기
답변 3개
선택된 해법
I had this problem after the update also. I figured out it only happens while I have "Hey Google" activated. If I disable the "Hey Google" feature everything works fine.
Google account/settings/voice/voice match, and turn off Say "Ok Google" any time.
이 답변이 도움이 되었나요?
점수 8
댓글 8개:
Thanks for the feedback. I also corrected the issue by disabling microphone and phone permissions in all apps that had those specific permissions. There were only 5or 6 total. The issue has happened since but I haven't pinpointed the actual app that is causing the problem. I will update once I do. Thank you.
Thanks Grandy, I can hear again. I contacted BLU and turning off "OK Google" is the remedy they're recommending as well, until a permanent solution can be found.
Your welcome. Glad to be of help.
Grandy, I thank you for getting me on track again. Your remedy is spot on.
Thank You... I have been going crazy with this issue. I was about to toss my phone and get a new one.
댓글 3개 더보기
댓글 달기
Hello, Thanks for easy answer!
Google Talk it's looks like it is a "Bug" or "Intercellular" and "google app" need to remove forever and put "Google Company" to Bring to Court for this interception to all Mobile Phones?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I have mi phone but I can't here in comming and out going calls
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Gabe 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 29
전체 시간: 27,071
