How to repair etch a sketch
This is an etch a sketch from the 80's. White knobs turn, but there is no drawing. Can I fix it?
좋은 질문입니까?
좋은 질문입니까?
An Etch-A-Sketch is a simple machine where the knobs end up moving a string from side to side and another from top to bottom. If the strings stretch or for any reason slip, you will get the behavior that you describe. Other than opening up the unit and replacing the string, there is not much that can be done.
Dan
이 답변이 도움이 되었나요?
This seems like the same problem: Can I fix dead areas on the screen, where lines don't appear?
이 답변이 도움이 되었나요?
지난 24시간: 6
지난 7일: 21
지난 30일: 115
전체 시간: 14,946
댓글 6개
Did any body find any answer to this problem?
lorriepwr 의
What if it’s leaking aluminum?
lorriepwr 의
I've heard of problems like this a lot so this could be a common issue with etch a sketches
Percy WONG 의
Mine just will not draw idk what is wrong with it if some one can pls help me that would be nice it is something I use to help with stress and paying attention and dont really wanna buy a new one if you can help me that would be amazing
Sarah Dearry 의
Mine stopped working the day I got it the vertical line knob stopped working -_-
London Miller 의
댓글 1개 더보기
