My Moto z2 Force needs help. people can't hear me unless my speaker p
Moto z2 Force
What can be the cause of the problem that I can hear the caller but they can't hear me unless my speaker phone is turned on.
좋은 질문 입니까?
Moto z2 Force
좋은 질문 입니까?
Hi,
Since you can be heard when using the speakerphone option, there is either a problem with the phone's microphone or perhaps the phone's voice inlet hole (found on the bottom edge of the phone) may be blocked with dust or lint.
To check if it is the latter, use a strong light and a magnifying glass to see whether the voice inlet hole appears to be obstructed.
If it is (or if you can't be sure), use a vacuum cleaner using short sharp bursts to see if this clears the obstruction.
DO NOT use a probe to try and clear it as you may damage the microphone which is directly behind the hole.
If you still can't be heard on a call after doing this then the problem is with the microphone. It is either faulty or has come loose from the systemboard.
해당 답변은 도움이 되었습니까?
Thank you so much. I would have never thought that to be it. It worked!!!!
Hi,
You're welcome.
Glad that you got it fixed OK.
Enjoy
Thank you, I had the same issue with my phone, And this worked perfectly.
That did nothing for me. :( I just got a CASEWE to try to add protection to my phone. Could that have messed up my cell phone?
24 시간 전: 1
7일 전: 3
30일 전: 4
전체 시간: 13,674
댓글 3개
This question was migrated from https://meta.ifixit.com/Answers.
iRobot 의
we had this on a moto 6g play, same thing,
read somewhere about 4g n 3g ,
go in your network setting change to 3g or other.
rogerdc20 의
Where can I buy a microphone?
Michael Killoy 의
