주요 콘텐츠로 건너뛰기
The Samsung Chromebook 3, introduced in 2016, is the successor to the Chromebook 2 and features an Intel Celeron N3060 processor. The XE500C13-K01US model has 2 GB RAM while the XE500C13-K02US model has 4 GB RAM.
Why is my Chromebook charging light flashing blue?
My school's Chromebook has a flashing blue light. Samsung support was not very helpful and just said to leave it charged and see if it powers on. Does anyone else have a solution for this question.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 6
댓글 1개
My samsung chrome computer blue lightblinking how do you fix this?
댓글 달기
답변 2개
가장 유용한 답변
If you can, remove the battery from the laptop and hold the power button for 30 seconds. Then try running the computer w/o the battery. If this works, give it a minute to go through the bootup process, and see if the light is still flashing. If the light is flashing, then it probably is the dead motherboard, or maybe power regulation. If the light is normal, just put your battery back in and see if it works, without the charger. If it is good, drain your battery, (I know, it's not recommended, just do it :D) and then once your battery is drained, plug in, with the LID CLOSED, and the COMPUTER OFF, and let it charge until the light turns green, signaling that the laptop is done.
이 답변이 도움이 되었나요?
점수 6
댓글 4개:
Dude Sam, thank you so much!!!!!
@Scott Georgson no problem! Glad it worked :D
You might not be able to do that. You have to ask your school 1st.
thank you Sam you just saved me over 500$
댓글 달기
Sometimes you just need to restart your Chromebook.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Cuthbert Thomas 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 11
지난 30일: 32
전체 시간: 19,092
