주요 콘텐츠로 건너뛰기
Huawei's 2016 flagship smartphone. Features a unibody case and dual rear-camera setup developed in partnership with Leica. Comes in 32/64 GB storage options and six different finishes. Model numbers EVA-L29, EVA-L19, and EVA-L09.
72 질문 전체 보기
Why is my screen turning off when brightness is set high?
Hi
So yesterday i changed my screen and battery on my huawei p9. I put in the charger, and things looked ok. Green chargelight was lit and screen was working. However when i changed the brightness to max, the screen turned off. When i tapped the unlock button i would only get a glimpse of my locking screen, before the screen returning to black again.
At first i thought maybe the new battery is sh*t, so i switched back to the old battery. Just the same thing happened again.
What can it be?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 4개
Ok so now i had a new screen in the mail and switched with the one thought to be defective. The problem is still there. The last time the screen went from working to black it made a noise similar to a condensator charging up (or emptying not really sure). So what can it then be?
Backlight circuit on logic board going bad. I don't know anyone that fixes it for the Huawei p9.
Thanks a lot!
The same problem here with p9. It might be silly but when i put the phone in refrigerator its fine for couple of minutes then i turn down the brightness and its all good
댓글 달기
답변 1개
선택된 답변
Probably a defective screen, nothing much else to it.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Jon 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 7
전체 시간: 1,750
