주요 콘텐츠로 건너뛰기
더 커진 Samsung의 주력 핸드폰, Galaxy S8. 2017년 4월 출시.
167 질문 전체 보기
Will not charge or turn on.
Went to bed and power was at 7%. Did not plug in charger. When I got up the next morning, phone would not turn on. Plugged in the charger, still did not turn on. Left it on the charger for one day, still did not turn on. Changed chargers and cords three times and tried wireless charging, you got it, still did not turn on.
In all situations the charging light never turned on, the charger never got warm, and the phone never got warm. However, when the phone is plugged into the charger and I do a soft boot, barely visible bars flash intermittently on the bottom half the phone screen.
An online search indicates this is not an uncommon problem and frequency is increasing. Verizon will honor the warranty because there is a small crack on the left side of the screen. This is been there for five months without causing any problems.
My thinking on possible problems:
Battery needs to be replaced;
Charging hardware Is defective.
Charging firmware or software is crap.
I am wide open to suggestions and troubleshooting. If nothing brings my phone back to life, is it possible to recover the data?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 5
댓글 1개
I had two Samsung Galaxy S4 that went dead.
One thing I observed, prior to their demise, was that the phones were warmer than usual when charging
My theory is that repeated overheating would cause some chips or circuits to fail.
I have bought an external charger for the batteries and bought also spare batteries, so that I will never have to recharge them with the cell phone again.
Just install a fully charge battery everyday.
댓글 달기
답변 2개
가장 유용한 답변
Try holding volume down + power for about 10-20 seconds and try turning the phone on again. Hopefully that helps.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Hey hows it going I had the same issuie and what I did is I started wirelessly charging it then went to try it again through the usb c port and it charged whih was like a week later so gibve that a try for awhile and see if it corrects itself down the road
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
댓글 달기
귀하의 답변을 추가하세요
Jack Zeigler 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 17
30일 전: 73
전체 시간: 8,840
