주요 콘텐츠로 건너뛰기
2011년 하반기 모델, A1278 / 2.4 GHz i5 또는 2.8GHz i7 프로세서.
591 질문 전체 보기
Using damaged pro hard drive as external drive
Hi there,
I have a mac pro burnt and I got some valuable data in the hard drive. Is there any possible way to recover it?
Or do these have a case that I can use this as external drive to other PC
TIA
Manu
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
선택된 답변
You may have some issues gaining access to the files if you have a Windows PC. Between the file systems being not compatible you may have files that are not openable in the Windows apps (some like MS Word & Excel will open).
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Yep that’s right. It wont have access to all the files. I’ve tried it and it can’t find all my files.
댓글 달기
가장 유용한 답변
If the hard drive isn’t damaged it should work fine. I have a MacBook Pro hard drive in an enclosure and I’m using it as a back up drive.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
First Do you have a Mac Pro or a MacBook Pro?
It your drive is a 3.5" you will need and USB to SATA enclosure. If a 2.5" drive a simple USB to SATA adapter will suffice. Let me know what you have and I'll give you a link to what you need.
Next, please tell us why you think the Mac may be burnt, did it go through a fire?
UPDATE @danj
I had one come in this week, the 13" 2012. Two years ago I had replaced the hard drive withy a sshd and also with a 2012 cable. I determined that the cable ad failed again. Put a brand new one in and set everything up. It worked fine then I secured it in place with the hard drive bracket and tighten everything up. Go to boot for a final check and all I get is a folder with a question mark!Opened it back up removed the bar and spotted some white on it in the middle. Turned it over for a closer look and saw a white electrical burn. It was right where the bar goes over the cable. Felt it and it's very sharp corner. Replaced the cable, snipped the part of the bar that covers the cable off with dikes and it's running fine. I have no idea of how many of these it have replaced thinking the bottom was causing the damage as the cable climbed onto the optical drive.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Hi there,
It is MacBook Pro.
I changed the battery recently and the tech who fixed it didn't do a good job it seems. When i plugged in the chargers, it burnt something internally .
댓글 달기
귀하의 답변을 추가하세요
King S 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 76
