Why is my tablet on Safe Mode?
Hi, I have a problem with my tablet. Whenever I turn it on, it's in safe mode. It seems that the DOWN VOLUME key is always pressed. Any way to fix it?
좋은 질문 입니까?
좋은 질문 입니까?
Volume down key needs to be fixed to keep the tablet out of Safe mode as when that is held down while the tablet is turning on, the tablet will boot into safe mode.
Either the volume down button is jammed or needs to be replaced usually. You may find mobile phone repair shops in your area that can fix this problem for you. Shouldn't cost much.
해당 답변은 도움이 되었습니까?
Thank you. I was very frustrated after continually pressing off and on again with no results. I have an older case for my tablet and it presses on the volume button if the tablet slides down in the case. Thank you.
24 시간 전: 3
7일 전: 6
30일 전: 23
전체 시간: 2,463
