주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Wi-Fi 전용 버전의 Apple iPad Air(모델 번호 A1474)입니다. 스페이스 그레이 또는 실버 색상으로 제공되며 맞춤형 A7 프로세서가 탑재되어 있고 16, 32, 64 및 128GB 용량으로 제공됩니다.
Multiple problems after screen replacement
(1) When screen is on, there's backlight bleed: I can see the light from 5 LEDs along the edge of the screen. (At first, I thought he'd misaligned the replacement screen.)
(2) The screen turns off and won't come back on until I force restart (Home+Power)
(3) Digitizer is unresponsive around the edges. (I have to flip the screen-sometimes several times-to close a tab, type an "A", use spacebar, caps lock, or Enter.)
1 & 3 were immediately apparent after the screen replacement. 2 started a few days later. I ordered the screen + digitizer pre-assembled (without Home button) from a reliable vendor we've bought from before.
This is so frustrating, I can barely stand using it. Everything takes 3x longer. My husband was emboldened to try this by multiple successful cellphone screen replacements.
Questions:
Could (1 and 2) mean he could've accidentally burned the backlight filters? If so, are they replaceable, or is there a workaround? Will I be handing over our firstborn to Apple in exchange for repairs? Or, is my iPad bricked?
What could be causing 3?
Thanks in advance for any advice.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
possibly a faulty lcd it happens, probably not the suppliers fault but you should ask for a replacement
Thanks, but it's too late for that, thanks to hubby's policy of aging everything. (In other words, he PROCRASTINATES.). It's going to a pro next. Strange, though, how the screen turns off and won't turn back on (which is WHY it's going to the shop).
댓글 달기
답변 2개
가장 유용한 답변
LCD has gone bad, need replacement if you want to fix the 3 noticeable dark light spots on sides of screen.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
i doubt its backlight filter issue as you have backlight, was the lcd replaced or just the digitiser
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
i missed that bit but no need to be sarcastic on your 3rd day.
I wasn't being sarcastic - just blunt. If you don't want to help, or don't have time to read what I wrote, don't respond. I was very careful to include all the relevant info in my post precisely so there WOULDN'T be a lot of questions back & forth. This is the only working device I have right now, and I need it to work. Using it is absolutely maddening; I have to keep flipping the %#*@ thing so the keys I need to use work. That post, which would've normally taken me less than 5 minutes to type, took OVER AN HOUR - and I'm NOT a patient person. How would YOU feel?
댓글 달기
답변을 추가하세요
Guiliana 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 39
전체 시간: 373
