I have a haier washer that makes a clicking noise when it agitates, it
It seems haier is difficult to find someone to repair
좋은 질문 입니까?
좋은 질문 입니까?
Hi ya'll. Problem with a Haier washer. I haven't seen one in years. Every one that I have seen had the same problem and it was in the transmission/gear case. Expensive overhaul needed. Recommendation would be to call Haier and check if transmission/gear case is under any manufacturers warranty. If so find out who does the warranty work in your area and schedule service. If its not under warranty you might consider a new unit. This job is difficult for a qualified tech, time consuming and expensive. Now, I can't be sure without hearing the noise and being at the unit, but from my experience this is your problem.
Good luck
해당 답변은 도움이 되었습니까?
Please give us the model number. Frankly I'm not knowledgable about a Haier machine. If it is a direct drive, take a look at this answer:
해당 답변은 도움이 되었습니까?
Gwt460bw , this brand seems to be very difficult finding anyone who works on haier
@ladytech are you around of this one?
24 시간 전: 0
7일 전: 14
30일 전: 36
전체 시간: 2,602
댓글 3개
@lhgarner what exact model is your washer?
oldturkey03 의
Gwt460bw is the model #
Lorigarner 의
Auto water slowly falls in machine
Shahzad 의
