주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 5.5” 스크린 iPhone은 iPhone 6의 큰 버전입니다.
1525 질문 전체 보기
Touch ID not working (2018)
Good afternoon,
I have an Iphone 6 plus 16gb running IOS 11.2 I've been dealing with a non-functioning touch ID for almost a year but have decided to try and fix it. I have repaired Iphone screens before and with this phone I did not however disconnect the battery before changing the screen. When doing the replacement I accidentally ripped the cable that comes from the metal LCD shield. I have the original home button and its cable and had bought an LCD shield online but once applied, it completely shut down my phone. Black screen unresponsive then I looked online for some answers, I learned to disconnect my phone from the battery and pressing the power button for 20 seconds (something like that) So my question is, having the original home button and the cable that is used from the home button to connect to the metal LCD shield and the original Iphone can I regain the use of touch ID?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 2개
I have a similar problem ,the touch ID not working. The apple tech told me that the screen and the home button come as matched paires, if separated the button worksbut the touch ID is lost, the only repair offerd was to replace the screen and touch ID button with a new set from apple $350.00 NZ
Paulo...
My iPhone 6pluse new Touch ID not warl
댓글 달기
답변 2개
선택된 답변
Chances are the replacement home button extension shield is defective.
What you may be seeing is that the phone immediately shuts down when it it plugged in.
You will have to get another replacement part for home button extension cable again.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
You should get touch id back as long as it's the same home button and same logic board they should still be paired. And yes make sure your first step after your home button is disconnected is to unplug the battery.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Rosario Ruiz-ruiz 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 3
전체 시간: 6,448
