주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2193 질문 전체 보기
Can you fix a iPhone 4 that has gotten wet?
I spilled milk on my phone and now it won't turn on or anything. Can it be saved some how?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 4개
선택된 답변
Yes it can be saved but you need to do as the first post says by removing battery and then get it to someone that knows how to do board level repairs.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
가장 유용한 답변
STOP using it! Turn if OFF fully and either keep it cool until you can get it to someone to clean it or you'll need to do it your self. Time is ticking! The longer you wait the worse it will be.
Any wet devices needs to be opened up to at least pull the battery so you prevent electrolysis as well as shorting out of the components. In addition the salts, acids and sugars in the milk will slowly eat away things.
Can it be saved you won't know until you try!
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Sorry about that ; but that's very easy don't worry we ate here to help you out just stop forcing it to turn on rather look for simple tools to disassembled your device and after that you will be able to clean it all then after you device will work again
Just follow this link iPhone 4S Teardown
That will help you my dia
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Is it simple enough that I could clean it myself
댓글 달기
It is simple but may be you may not have the tools and may be buying them also may be more expensive than taking that phone to a repair shop and they help you do it. I think that will be helpful
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Amanda Moore 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 73
