주요 콘텐츠로 건너뛰기
2017년 11월 4일 출시. A1865, A1901. GSM 또는 CDMA / 64 또는 256 GB / 은색 또는 스페이스 그레이. ("iPhone 10"으로 발음합니다.)
1199 질문 전체 보기
Question about Face-ID and replacing the screen.
Hi there, I'd like an answer from someone who has actually replaced the iPhone X screen.
There are some rumours that Face-ID will stop working when you replace just the display, and some deny it.
How was the repair and did Face-ID stop working?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
If you only replace the SCREEN(don't replace the sensor flex cable), the Face ID will still work. if you replace the sensor flex cable, the Face ID will fail. More about the Face ID repair you can visit here:Why iPhone X Face ID not work after repairing
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
If you replace iPhone 8, 8 plus or X screen you need to copy the firmware data of the original screen into the new screen. The needed tool is under development. I saw some working versions, what are tested and working with IOS 11.4 and 12.0 Beta. The screen data can be cloned only to OEM screens for now.
Afte the copy of the data, the light sensor works well again.
If you would like to know more about this problem read this article: http://www.futuresupplier.com/blog/solve...
Box: http://www.futuresupplier.com/iphone-8-8...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
nicolay.94 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 2,055
