iMac won’t boot with built-in display connected
It had a damaged 30-pin display connector (torn off by previous owner) on the logic board & also some minor damage to the 30 pin ribbon cable.
I bought a replacement connector and ribbon cable from eBay, just to be sure it would connect properly.
Numbers listed on eBay for the ribbon cable:
Part Number: 593-1006 922-9132
MPN: Y593-1006 922-9132
I reassembled the machine, but it would not boot at all. No startup sound, no beeps, nothing. However it does boot with the display disconnected.
I have ordered an adapter, Mini DisplayPort (Thunderbolt) to VGA/HDMI/DVI, to see if will run with an external display, as a workaround.
But I would much rather fix it properly, so it runs with the built in display. Can anyone shed some light on this?
Update (02/07/2018)
- Only 1 LED's is on with all 4 monitor cables which I think is LED #1 as it is a little hard to see through the vent.
- All 4 LED's are on with LVDS cable disconnected.
- All 4 LED's are on with LVDS disconnected & backlight power cable connected.
- All 4 LED's are on with LVDS disconnected, backlight power cable connected & the vertical sync ribbon cable connected. I am also getting a very dull grey illuminated screen/monitor & 3 minutes 10 seconds later screen/monitor goes dark i.e. from the dull grey.
Update (02/10/2018)
Schematic mentioned below:
좋은 질문입니까?
댓글 3개
Hold on here!! You need a mini-display port cable, NOT a Thunderbolt cable! While they look alike they are not the same!
DanJ 의
What does the built-in diagnostic LED's telling you?
DanJ 의
@ifixanythink "damaged 30-pin display connector (torn off by previous owner) on the logic board " post some pictures showing the damage on the board as well as the complete board. That way we can see what you see 기존 질문에 이미지 추가하기
oldturkey03 의
