주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
New Nintendo 3DS XL로 알려진 Nintendo 3DS XL 2015년형은 2014.10.11에 일본에 출시되었으며 북미에서는 2015.2.13에 출시되었습니다. 대한민국에는 2015.5.1에 출시되었습니다.
Black Screen of Death (CFW)
I had my new 3ds sitting on my desk, closed, with the power still on when I knocked it off by accident. I opened it up to a message saying the sd card was removed. I shut it off to restart it only to be greeted by nothing but 2 black screens, and only the blue power LED lighting up. I'm not sure if it should be mentioned, but I do have custom firmware installed on my 3ds. Never had a problem with it before. I know that taking out the wifi card and putting it back in is normally a solution that fixes this problem, but I just wanted to know if there is anything else I should do first if my issue is unique in any way.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개:
Press and hold: D pad up + LB+RB+A+Power button. It forces a reboot and update
What do u do after that? After the update it turns off tho…
댓글 달기
답변 1개
Try the wifi card thing first. If it doesnt work, you can get the bottom screen to work by taking the left shoulder button off and gently prodding around with tweezers. If you get the bottom screen to work, thats a start! I don't know how to fix the top screen, and once the shoulder button is off, you can't really get it back on. If you want the top screen to work,you should get repairs. But anyway, I suggest trying to place the wifi card back into its original spot!
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
the ribbon cable for the bottom screen is nowhere near the left shoulder button; those are however the cables for the top screen though
댓글 달기
답변을 추가하세요
Cal 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 11
지난 30일: 31
전체 시간: 12,674
